Canon PIXMA MX850 multifunction InkJet Printer Logo
Posted on Nov 15, 2012
How to fix a Canon MX850 printer
The printer was installed. It does not work. I need to uninstall and then install the printer on my dell desktop
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jan 10, 2008
SOURCE: Install canon i350
Go to this site. You can download the drivers.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jordan Bosch
  • 45 Answers
  • Posted on Dec 28, 2008
SOURCE: I am re-installing my canon ip5200r printer...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11994
Click select OS and then select your version of windows then install what pops up under drivers. This is your backup if the cd doesn't work
Anonymous
  • 184 Answers
  • Posted on Apr 26, 2009
SOURCE: printer canon pixma mp190 installed need to chage to english
Since you have your printer pre-installed in Arabic, your best option is to get the english version of your printer driver and re-install it.
when you get to the link i will leave you with. download the file with this name:
mp190svst100ej.exe
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16981
A Soveral
  • 566 Answers
  • Posted on Aug 19, 2009
SOURCE: how to install canon printer MP140 without a disk
You can download the drivers and software for your printer from CANON:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15294
Click on the "Drivers and Downloads" tab and then select you OS.
Anonymous
  • Posted on Sep 06, 2009
SOURCE: printer won't turn on ( mx850 )
I believe the fix is to disconnect power cord for an hour or so.
This is truly maddening... it's a bug in the design of their power supply.  It's happened to me three times in the past few months.
The first time it happened, I haplessly stumbled onto the solution wisdos mentioned (unplugging it for a while) without realizing it.  I thought it just started working for no apparent reason.
The second time I tried all sorts of tricks (not remembering the fact that I'd disconnected the power for a period), spoke with Canon support several times and finally had to agree to have them send me a replacement printer.
I'll skip the part about not being able to get the old printer's print head and inks out to put in the new one because it wouldn't budge without the power being on.
Now, with second printer and a five-second power failure, the same deal... won't turn on.  This time I pulled the power cord from the printer and let it sit for a few hours.  Plugged it back in and it came on.
The maddening thing is that Canon support didn't want to escalate this to someone who might understand the power supply and diagnose the problem properly... their solution was to send out a new printer.  What a waste of time, money, and effort.
1helpful
My printer only prints off 1/16 of a page and then goes to the next page. The printing is incomplete.
Hi there try to reset the printer & then try. I hope its give u success. After that if u not success then uninstall the printer from PC restart the PC & printer & again install the printer. Then try.
I have a canon mx850 and need to reinstall it and cannot locate the installation discs...what should i do?
If you go to the following site and select your operating system from the dropdown menu you will be able to download the required software.
http://software.canon-europe.com/products/0010549.asp
Can you tell me where the ink cartridge is located in the cannon mx850? thank you!
Dear friend,
You can find the solution by downloading and reading the on-screen manual file of Canon PIXMA MX850 All-In-One InkJet Printer by clicking the link which I insert here.
In the opened web page, find Guides and Manuals section and under the explanation “MX850 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000)”, click on the mx850sosmwin100us.exe file link.
When you click the file link mentioned above, in the new opened page you will see “I Agree-Begin Download” button at the bottom. Please click on that button to download the file named mx850sosmwin100us.exe and save it. When you run it double click on it, or run the file during downloading directly it will install the “MX850 series On-screen Manual” software. You can fin its icon on your desktop or find the link in the startup programs menu.
When you run the installed on-screen manual program, click on the “User’s Guide” and on the next screen scroll down the left menu. Click on the “Replacing an Ink Tank” menu under the heading “Routine Maintenance”. You will find all the information you need.
You can use this on-screen manual for the other issues when you need help about your Canon PIXMA MX850 All-In-One InkJet Printer.
I hope it helps.
If you vote for the answer, this will help the others to see the solved similar problems.
Sincerely.
1helpful
Urgent help to install ink please...damsal in destress!
Go to:
MX850 Support
On the "Support & Service" tab, type replace ink in the "Please enter your question" box.
Click the Search button.
On the results you should see "How do I replace or insert an ink tank?" Click on it.
There will appear instructions complete with photos and animations to help you along.
Thanks for using Fixya.
Lost installation disk for Canon mx850
plz check the manufacture website for the driver download
old marine
old marine
ZJ Limited
ZJ Limited
