Washer will not work
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
SOURCE: Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
SOURCE: Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
SOURCE: washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
