Error says "Wireless capability is turned off". Where do I turn it back on? Windows network diagnostics is telling me I might have accidentally switch off the wireless capability switch which I cannot locate. A wireless network is available and working on my other pc and i-Pad.
SOURCE: Cannot find wireless switch for my Gateway cx2610
It probably is a small switch on the front or the sides of the computer. If there is not one, then it is Fn+something like F2.
SOURCE: i have a gateway laptop computer thats wireless.
First, look at the status lights that indicate what is going on with the computer, they are the line of light icons that run along the bottom of the touchpad. The wireless icon is the second from the left. Is it on or off? If it is lit, it is on....if it is off, the wireless is off. If none of the lights are on, the lights be turned off....try holding down the "Fn" key and tap the F1 key, this toggles the status lights on and off. The notebook ships with the wireless radio turned off. The radio is turned on and off by a system key combination. In the case of your laptop, hold the "Fn" key down and tap the F2 key...this toggles the radio on and off.
SOURCE: wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
SOURCE: I cannot locate the wireless switch on my Gateway 5300.
http://support.gateway.com/s/Mobile/Solo_Series/p5300/8508143/08143.pdf
follow this manual ..here u can find the answer for ur problem ..
SOURCE: wireless network capability to gateway t-6630u
click on start then click on control panel then go to system then click on hardware then click on device manager then click on network adepter and see is there any red or yellow mark if it's there right click and click on left click hardware scan it will work or run the driver cd on the computer
