Sony KV-36XBR250 TV Logo
Posted on Feb 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony KV-36XBR250 TV, I get sound and piucture perfect for my cable box(Verizon Fios RCA), I try connecting anything else an d the picture wont show up evern through same connection. I tried different cables, differnt things to hook up(xbox 360 ande Blu-Ray Player). Can anybody help?
Larry
Level 3:
  • Sony Master 5,042 Answers
  • Posted on Feb 10, 2018
Larry
Sony Master
Level 3:
Answers
5042
Questions
Helped
1239518
Points
18413
Try a different input source and see if that works
5 Related Answers
Anonymous
  • Posted on Jun 13, 2007
SOURCE: Sony KV-36XBR250 - no picture, good sound
This is a common failure mode (which I now share), and has nothing to do with the picture tube or surge protection. From the forums I have searched to-date, it appears to be a failed component in the flyback circuitry, but Sony will not admit to an inherent defect. If anyone has ACTUALLY FIXED this problem, please post a reply. Guessing won't help anyone. Thanks.
otacon
Damen Wong
  • 1950 Answers
  • Posted on Jan 20, 2008
SOURCE: No Audio
Your receiver is the Denon AVR 2105 and not the Sony STR-DG510 5.1 Channels Receiver?
A
Anonymous
  • Posted on Mar 13, 2008
SOURCE: blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
Anonymous
  • Posted on Jan 20, 2009
SOURCE: HDMI port does not work on the KV-30SH420
I dont have a TV with HMDI input but i do have a computer moniter. To change i have to press a button that changes from VGA to HDMI. My computer supports HDMI and when i tried it, it works. Try looking in your manual for a way to switch input methods.
Anonymous
  • 132 Answers
  • Posted on Feb 01, 2009
SOURCE: STANDBY LIGHT KEEPS BLINKING BUT NO PICTURE OR SOUND
just try unplugging it for a little bit and see how that works.
Verizon fios set top box
well basicly you have to make sure all the right cords are hooked up right if not do so if it still doesnt work GET AN NEW ONE!
1helpful
Sony KV-36FV1 TV/INPUT Problem
Your TV has "Setup" function button on its front panel. By this button, you can enter its input selection window. Before testing this, check all the interconnections once more. Download its user manual. If you feel any difficulty in downloading it, send your email address to me and get a copy of it back by return mail. It has all wiring illustrations. If wiring is correct, it should accept the DVR signal.
THE CABLE CONNECTIONS ON THE TV IS BROKEN IS THERE ANYTHING I CAN BUY THAT WILL CONNECT TO THE TV SO I AM ABLE TO VIEW CABLE?
No.Tried telephone cable services like ATT U verse or Verizon Fios.Their boxes can used RCA AV component cable YRW cable connections to YRW component cable connection holes with both of these companies boxes to watches tv.
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
2helpful
No picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Sony TV Won't Come On
Thats great, problem resolved.
Please rate solution as fixya ( 4 blue diamonds)
Thanks.
Can you help me?
go to verizon.com and look up fios tv and then from there go to installation and then troubleshooting
Blinking picture
No Sound
sounds like you are using componant cables.[ red,blue,green on the right side in back of the cable box for the picture, & red & white cables for the sound.] make sure the red & white cables are connected to the middle white & red outputs of the cable box to the tv's red & white inputs, not outputs. hope this helps.
wg
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
