Question about NorStar Meridian M7310 Phone
Phone won't ring. The arrow will flash but no ring. Meridian 7310
Something is blocking the phones from ringing when a call is coming in. The arrow flashes when a call is coming in but does not ring. The ring tone is set and the volume is up but no ring. the ringer is set and while setting it the phone does ring during the test. the phone was just purchased used and has been like this since plugging in the phone.
  • 30 Answers
You can try to plug it in at a set that does ring and make sure it wokrs there. The programming should not have changed with the phone but ... anything is possible. If it rings at the other location then it will be the programming for that extension. Also check that it is not in DND do not disturb
Posted on Jan 07, 2009
SOURCE:
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
INCREASE RING TONES FROM 3 RINGS TO 6 RINGS
Generally (without knowing what phone yopu have) you need to press menu, arrow up to answermachine or TAM then press OK then arrow up to settings or TAM settings then press ok then arrow down to answer delay/ring delay/ring number press ok then use arrow keys to adjust rings, when on required number, press ok.
Feb 25, 2011 | Cell Phones
How to change ring tone? Lost manual.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 16, 2009 | Uniden Cordless Phone
Just got this used phone for school.how to change the ringtone It's a very annoying one now.
Jul 15, 2009 | Uniden Cordless Phone
RING TONE VOLUME TO LOW
While the set is ringing use the volume arrows next to the handset to adjust the volume.
Mar 26, 2009 | Samsung Prostar DCS-24B-LCD Corded Phone
Need to change my ring tone in Fax Canon laser class 2050 G3
Press dataregestration,use the arrow to go to rx settings,select rx settings with the set button,go to incoming ring,select and switch it to on,and then cange the ring count to the amount of rings you desire.
Jan 06, 2009 | Office Equipment & Supplies
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
How can I block a number on my iphone?
A lot depends on your model of phone.
My phone I can assign a specific ring tone to each phone #. So annoying numbers I have assigned them as a Mute ring tone.
When you edit a phone number, it should give you options as to blocking, assigning a ring tone, saving etc.
Please rate this solution
Jul 31, 2008 | Cell Phones
Telephone ring tone
press flash on phone til you reach desired ring tone then pick up headset to set
Sep 26, 2007 | Innovage 1604007 Corded Phone
NorStar Meridian M7310 Phone Logo
1,758 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
