I have seen a number of domestic rotavators but haven't yet seen one with a reverse gear. You didn't make it clear in your description whether yours has a reverse gear and that is all that is working or whether it usually only moves forward but is moving backwards?
While it is theoretically possible for a 2-stroke engine to run backwards, your engine is a 4-stroke that is incapable of running backwards and so it would seem the gear selector is stuck if it has one or someone has carried out repair work and made a mistake or something else is broken.
The only thing that comes to mind is some of the older designs used an over-long drive belt that crossed in the middle like a figure eight in order to reverse the driven pulley and replaced the belt with one that seemed the right size would cause the machine to run backwards.
funny, you can fix this real easily, you just need to flip flop the cables on the motor, currently the polarity is reversed, theres only two wires connected to the motor just switch them around
The problem is a worn shift fork in the transmission. Replace the forks and check forward gear pinions and forward shift dog pinions for wear and replace if they show any signs of wear.
