To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
SOURCE: 1996 Toyota Celica remote security system no longer works
Hi, Contact your dealer and get instructions for reprogramming your remotes. When a security system loses power for an extended amount of time the programming for the remotes are lost.
SOURCE: 1996 Toyota Celica GT: car loses power and stalls out.
Check alternator voltage at back of alternator ( big wire ), if you have no less then 13.5 volt's, alternator is ok, check for blown alternator fuse or break at wire from back of alternator to starter then to battery, could be a bad fuse link at starter.
