Need to know colour code of wires in boot for the plug to fit on
SOURCE: changing spark plug wires in 1998 camry
You aer not clear about your problem, when replacing plugs and wires all the boots need to stay in place, the larger boot goes around the spark plug, making sure the metal is secure around the tip of the plug, the oppisite end fits the distributer cap, making sure the metal at the end of the wire is securely in the hole. You said you have 3 boots, you should boots for each end of each plug wire and a plug wire for each spark plug
SOURCE: kia optima 2004 transmission selector wiring colour diagram
Try this website www.kiatechinfo.com
This will be far more usefull than me just handing you the diagram
SOURCE: wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
