I have a Maytag Neptune Washer (Model No. MAH6700AWW) that was purchased in August of 2006. Beginning today, I am unable to change the temperature setting and there is a smoky smell. This unit was fixed several times under warranty. Now this. Can you help me as soon as possible. rlb
SOURCE: I am looking for a
Your washer was manufactured in Jun 2005, if it's a fairly new model. As far as service manuals are concerned, you can find it at managemyhome.com. I downloaded your manual but was unable to send it via this format. You will need to create a user name and password and then click on the "Find Product Manuals" under the HOME heading. Follow the step-by-step instructions. The documents are available in .pdf format. You will need Adobe Acrobat reader to view them and the service is free. I hope this is what you were looking for.
SOURCE: Maytag Neptune MAH6700AWW water won't drain into drum
Power off the wall. Drain water & check your pump for blockage. Filter as well.
SOURCE: washer will not drain or run. It gives a code nd
pull back off washer and check your waterpump
