Minolta magicolor 2300W Laser Printer Logo
Posted on Jan 06, 2009
To change opc drum in konica minolta
How to change the opc drum in the laser printer konica minolta 2300w magicolor
gregg_morris
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Mar 13, 2011
gregg_morris
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
2132
Points
8
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Anonymous
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Feb 24, 2009
Anonymous
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
839
Points
Search the web for the users guide. Instructions are under "replacing consumables"...dvw
How do I change the OPC Drum cartridge? I cannot find any instructions to get to it.
Open the front door.
Remove the toner waste bottle.
Turn the belt tightening knob (top middle with arrow on it).
Pull out the OPC Drum.
Install new OPC Drum.
Turn the belt tightening knob back.
Re-install a waste toner bottle.
Close the front door.
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
OPC drum out ? What is this what should I do? this is on a Konica Minolta mc 2550 PS
please repalce the drum unit wich is inside the mechine you can easily change it
Just warms up and then flashes Error next Ready light
The OPC DRUM needs to be replaced. Near End of Life.
Display Window will show Drum Near End. (About 4% or 5% left)
I posted articles about this on other problem solve pages here.
Look them up.. . . .
Driver
Here is the link to download your driver.
Thanks
Replaced Black TOner but still says it is empty
One way you could reset the toner is using the service mode.
Is this printer a 2300w ? If so, open the front door of the printer, turn on and hold down the cancel button for at least 20 seconds, that resets all the counters to factory defaults. The only problem is, that it will set all the toners to 100% and standard capacity, but you can change that in the software. One good thing is, it sets the OPC drum,
Fuser unit, transfer belt, everything to 100%
Delboy
Minolta 2300w windows vista
try changing a usb cable vista should find some new hardware
How do you change the drum cartridge ?on a 2300 qms minolta printer
Replacement of the OPC Drum Cartridge
1. Open the Front Door.
2. Remove the Waste Toner Bottle.
3. Lower the unlock lever and remove the Drum
Cartridge.
4. Reinstall the new Drum Cartridge
5. Pull the protective sheet of the Drum Cartridge to
the front and remove it.
6. Raise the unlock lever.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
