Ok i understand now what the nd error code mean but now how do i repair it??? please someone help!!
SOURCE: maytag neptune frontload washer code nd
Yes maam, I sympathize with the situation. The "nd" code on the Neptune is usually a pump related issue. Check the drain line for kinks first, and then the pump will have to be checked. No matter how diligent we are, inevitably hard objects like pins, coins, etc., make it into the washer. Remove the hoses from the pump and using a flashlight, look into the suction port and check for any obstructions. Also check the pump impeller for any broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hard objects that make it to the pump can damage the impeller blades on the pump. Sorry for your trouble and I hope this helped. Best wishes.
Testimonial: "canbruce75 was extremely helpful. His directions helped know where to look for my issues. Thanks so much!!!!"
SOURCE: MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
SOURCE: ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. Please get back to me if you have any other questions.
Kevin
