Motorola dct6416 III - recorded programs appear blank
When I go to my recordings, I can see the programs in my queue but when I try to watch one, the screen is blank. Even when I try to watch programs I've watched before I get a blank screen.
Re: Motorola dct6416 III - recorded programs appear blank
I ended up calling Motorola who suggested I unplug the power cord from the machine for 10-30 minutes. When I powered back up, I had to give the machine time to reboot but after about 10 minutes with power on I was able to access my recorded shows.
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
this works to record progam you watching 1. press menu key 2. highlight DVR button by using either < or > key then press OK button 3. answer prompts
Do this to set up a recording in advance or a series recording 1. Hit the guide button 2. scroll thru channels until you find program you want to record 3. scrool over to red dot press OK button 4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
I was just reading another blog on this problem and it seems you must clear any recording setup you have for the program the go to the settings and in the history file delete all listings of it. This can take a while as you must delete them one at a time. Then you can reset the series or single recordings. Seems to work for some people. I am having the same problem and programs are disapearing one at a time. Good Luck
Smalltown
