Don't works flash key, need to adjust time flash
SOURCE: how do i conferance call on a polycom voicestation
The conference call feature is not part of the phone, but part of your telephone network. In some systems you press a sequence of keys to conference in another member such as flash #02 but it depends on what telephone network you use. Contact your IT admin and ask how to trigger the feature on that analog line.
SOURCE: How do I receive 3
you cant
you can only call out to multiple people not receive multiples
try using a conferencing bridge so all people can call into one number and be connected that way
SOURCE: I have the Polycom VoiceStation
Hi, I have never really though of those brand devices as all that good. I recommend Konftel, they are simply the best. With Aethra, a close second...last is .......
Just get the top of the line one, and you will NOT be disappointed.
http://www.telecom.co.nz/content/0,8748,101437-201060,00.html
BTY, I expect that your unit is faulty, the electret mic's aren't very good, and fail quite a bit, as with all cheap electret's, and also check positioning too, this can make a difference too, make sure nothing is around to reflect the sounds as this is what makes it echo and sound bad, regardless.
