SOURCE: Have Challenger Type C 2100 circuit breaker in
First HACR is heating, air conditioning,refrigeration. So in other words you could use it on an electric furnace or air conditioning.
IS this the main breaker for the panel? or for and electric furnace. I'm assuming its for the furnace, perhaps back up heat for heat pump. See if there is another disconenct on the furnace, turn it off and see if the breaker resets. IF so you have a short or overload in the furnace.
If' it IS the main for the panel, turn off all the other breakers in the panel, and try to reset the breaker. If that works, turn the other breakers back on one at a time. IF it "POPS" then it is tripping. Don't keep resetting, find the problem.
SOURCE: I have a residential panel with all Challenger
You should only use breakers listed for the panel you have Look on the inside cover of the panel and see what breaker numbers are listed. Many breakers will fit, but are not listed. They are both 15A, but you didn't indicate what brand of panel they are installed in. Most likely, the GE breaker was added,
