Makes gray copies
Has the developer been replaced and the required F8 run along with the drum counter reset. Also was the F5 run and F3 all of these F# are run in service mode.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Help please - my Minolta EP 1083 won´t work properly.
did you try to cleane the optic section ,make sure to remove the lens cover and clean mirror on the right side too underthe len cover,2 remove drum check and c if toner on drum?
SOURCE: minolta cspro 2080 having black copies
chek the scaner lamp(upper lamp ) if its working during copy other ways u have to take up the lamp and check it by oem meter , u have to check also the thermal fuse for that lamp on the same unit. I hope that will solve ur problem ,if not high voltage unit above the drume is damaged.
SOURCE: code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
SOURCE: I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
SOURCE: Describe your how can I
Hi.
If you want to attempt resetting the counter enter in service mode and do a Timer Reset.
If you have replaced the drum (or if you need to replace it), then you have to perform the auto image density control procedure.
To reset the meter count:
enter service mode: stop, 0, 0, stop, 0,1, find meter count and reset. This should be done by pressing "1" to access meter count, then press"8" to display counter on the zoom display.
Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.When you see E in the display, press 5 and the copy(start) button to perform the auto image density control procedure.
