Question about Lanier Office Equipment & Supplies
Lanier 5627 Clear Service Code SC320
Tried steps going into service mode. when I turn back on it's still there. Anything else?
3 Suggested Answers
SOURCE:
firecontrol7
  • 6850 Answers
SOURCE: Machine Error E$-02
To enter service mode you press Function orginal size ledger and "3" simultaneously once in F9 -6 -04 for fuser reset. If it comes back need a new fuser unit:( or worse main board.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Apr 03, 2010
santosj27
  • 263 Answers
SOURCE: What is the service mode for a Lanier 5627?
Why you continue to ask the same things? Why do you continue to put new posts? If you answer when I suggested that perhaps you have your problem solved.
Posted on Jan 22, 2011
Lanier copier 5613 Error Code 549 What is it and how do I reset?
SP 5-810, press 1 hold down OK and original type key at same time to reset. -Carl
Nov 21, 2014 | Lanier 5612 Fuser Spring For Picker Finger...
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
Jan 22, 2011 | Lanier Office Equipment & Supplies
Lanier model 5627 with fault code sc542 upon power up.
LOL I think I already gave you a solution try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
Lanier model 5627,fault code SC542 upon power up
try this:
6. Turn ON
And thats it
Jan 22, 2011 | Lanier 1205 Copier
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
How to enter service mode on a lanier ld225
Press Clear/Modes, then 107, then press AND HOLD Clear/Stop
This will get you into the service mode screen.
Know what you are doing before going into any modes and changing anything.
Good Luck and Thank You for using Fixya
Jul 20, 2010 | Lanier Office Equipment & Supplies
I came into work today and the copier said funcional problem call for service. this machine has been working fine how can I clear that off of it? It also is showing a sign SC320 and a phone number to call....
You did not state the Make/Model but this is a Ricoh/Savin/Lanier/Gestetner failure code so I will go with that.
SC320 is a laser mirror motor failure, also referred to as the laser scanner. Most likely this code will not reset, but I would at least try powering the machine off then on to check. If not, I am sorry to say this will require a trained service technician to replace. Parts and Labor approximate cost should be around $360 depending on model.
Good Luck and sorry again to be the bearer of bad news.
Oct 23, 2009 | Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Open Questions:
26 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
