Akai PDP42Z5TA 42 in. Plasma Television Logo
Posted on Nov 14, 2012
Tv will not turn on - Akai PDP42Z5TA 42 in. Plasma Television
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Cracking speakers when tv turns on
If other electronics are too close to a TV this is a common problem. Try moving the 2 items at least 2 foot away and see if that helps.
You may not want to leave them there, but at least you will know if that's the problem!
2answers
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
4answers
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
4answers
Closed caption always comes on when I turn on TV!
Same thing here!!!!! It is soooooo annoying! Can't do it from the TV and the CC does not turn it off either.
Any suggestions would be so appreciated.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
