Question about TP-LINK Tenda W311R WirelessN Router AP 4port Switch 150Mbps
Tenda router input eror
My router will not connect to my windstream modem and the internet. when i go to 192.168.0.1 to setup, the page asks for my username and password provided by my isp. when i enter them it goes to the same page and the top says input error. I've tried all of the troubleshooting tips found online and nothing works.
    President:
  • 623 Answers
It's not the username and password from your ISP. If you try to access your router and you have not changed anything, use the following values:
username = admin
password = admin
Once in the router interface, you will have to configure the router for your DSL-modem (I guess it's DSL since Windstream does not produce cable modems.)
Here fill in the username and password your ISP provided you with.
Let me know if you have any questions.
Posted on Nov 14, 2012
SOURCE:
SOURCE: After using TP-Link TL-R480t+ Router Video streaming from internet at sites such as youtube does not work at all
Hi ,This is Clare Su from TP-LINK support technical force.To you issue,I have the following recommendations:1. try to use only one line to connect to the internet,and see if you can watch the video on youtube2.if you can see the video with one line connected to the internet.Then,you can get another internet line with the router.And you can try to set the rule to the website: youtube, let the flow from youtube come in and out just from one wan port.if you can't solve the issue with my recommendation,you can email me. I will help youas soon as possible.My email is:clare.su from tp-link.com
Posted on Nov 23, 2011
SOURCE: trying to set up for
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 20, 2011
male_28_cam
  • 1555 Answers
SOURCE: I have a TP-Link TL-WR941ND
Can you kindly let me know the settings on your modem and router. Whether they are connected via using bridging mode or ppoe mode. In order to find this simply enter 192.168.1.1 in your browser and enter user id as admin and password as admin and hit enter. In advanced lan settings just click on first right hand side edit button and click next and see wether ppoe is selected or bridging is selected in order to ascertain the ip of wifi modem simply click on start button when connected to internet via wifi modem and select run type cmd and hit enter in the black window type tracert www.google.com wait for few seconds the first ip in the list will be your modems ip. use the same method as described above to find which way is it connected to server bridging or ppoe.
Posted on Jun 15, 2011
  • 98 Answers
SOURCE: My tp-link TD-W8950ND 150Mbps Wireless Lite
this is because your modem is out dated your better off getting a new one
Posted on Mar 20, 2011
SOURCE: I have TP LINK WAIRLESS
If after Reset that problem still remains, as a browser use Opera !!!
Posted on Jan 13, 2012
I can't login to my Tenda AC1750 Router using 192.168.0.1 or 1.1
TENDA W300D connection problems Green lights but no connection solved
although a different model
this might help for apple users as it worked for me!
i think my problem ocurred after an update to mac software.
my service provider could not resolve it but i did. :)
1) select settings
2) select network
3) view ethernet if it shows a green light and states connected yet you can not connect to any web page or your set up page for TENDA
4) select the apple logo top left of desktop screen
5) select location
6) select Automatic
this is what was stopping my apple mac from connecting even though i could connect ok with iPad.
now try your browser again
7) contact your service provider and get all the details to fill in on your modem/router set up page.
i only have the aus info:
download soft wear updates from: www.tendaanz.com.au
www.tenda.cn
tel tenda (sydney aus) 0284057583
Sep 29, 2013 | Computers & Internet
Unable to configure the repeater mode.
Tenda router is a very good network service provider, Tenda router has more than a million users across the country. It has provided high-speed internet, multiple sharing options, easy for connectivity with other devices and etc. But some time router users faced problem with this router service and not be solved to the issue, we are providing a Customer Service which is Tenda Router Customer Service Number. The customer contact by dialing a toll-free number +1-833-284-2444 and get immediate solutions.
When Tenda Router Not Showing Internet Light:-
Follow the given instruction and make problem free with your Tenda Router.
l First of switch off your modem & router
l Give it a rest and wait for a few minutes
l Switch On the modem & router
l A blinking light for internet connection will appear
l It will get stable in few seconds
l If you see the stable green light that means the issue is resolved.
When users get trouble for configuration contact our customer service number and get the solution for configuration, Tenda router service is wired and wireless service provider which solves the problem by taking just a minute and give the solutions. Customers also can get connected with Tenda Customer Service in case you find any issue.
Tenda Has genuine interface for his customer and providing guaranteed services. Some time customer wants to another technical service and they are can't take solution by a service number so we have an all technical solution platform which is providing any kind of services so visit our service number website and get solutions.
https://servicenumber.org/tenda-customer-service.html
Mar 07, 2017 | TP-LINK TL-WA500G 54Mbps Wireless Access...
Tenda w308r has no signals
It's because Tenda W308R is a router, not a modem.
If you don't plug it to a modem, in spite you see the lights on you will have no internet connection.
P.S.: I have this router, which I bought by mistake with the hope it worked as a modem
Feb 19, 2013 | BestPriceCables Tenda W308R 300Mbps...
How to install tenda wireless router
Plug in the router and connect it to your computer via a WIRED connection. Connect the cable into the Tenda router in one of the yellow ports labeled 1-4 (which one specifically should not matter).
Open a web browser and go to http://192.168.0.1.
When prompted for a username and password, enter "admin" for the username, and "admin" for the password.
Click "WLAN Settings", then "Basic Settings".
Click "Enable Wireless" if it is not already checked, and enter a new name for your router in the field labeled "SSID". The default name is "Tenda", but you can choose any network name you like, so long as it is made up of only letters and numbers. Leave all other settings on this page at their defaults, and click "Apply".
Now, click "Security Settings".
In "Security Mode", choose a network security type and enter an appropriate password. For demonstration settings, choose "WPA Personal". Make sure "AES" is selected, and then enter in a pass phrase. This will be the password for your wireless network, so be sure to write it down. The default is "PlsChangeMe", so go ahead and change it now. Leave the "Key Renewal Interval" field at its default setting, and click "Apply".
Click on "WPS Settings".
Click "Disable", and then click "Save".
Click "System Tools", then "Change Password". If you want, change the username and password here. You will need to enter the new username where it says "admin", then the old password of "admin" in the Old Password field. Then, enter your new password in the "New Password" field, then again to confirm it.
Close out of the Tenda configuration page.
You have successfully set up your home network. When ready, connect your modem to the router using the blue "WAN" port on the back of the router, and powercycle your modem and router, and internet will then be available on your home network.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 29, 2013 | Computers & Internet
I have windstream for my internet provider and I got a new modem and now I can't get the internet to connect on my second computer through my linskys router...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 14, 2010 | Linksys Wireless-N WRT150N Router
I am trying to hook up xbox live for the first time. i have a isp windstream and a speedstream 5200 modem. My connection is good verified by windstream but x box cannont connect to the signal. Winstream...
  1. Step 1 Have your Xbox 360 correctly hooked up to television with HDMI or component cables. Turn your television and Xbox on. Make sure your television is on the correct input. Make sure that your WIndstream DSL Modem is on. If you have a router, make sure that it is on.
  2. Step 2 Obtain the security key for your wireless network, and write this key down. You will need this key to allow the Xbox 360 to have wireless access to the Internet. If you do not know where to find your wireless network key, you will have to access the security setup of your router. The way to do this varies by model, so check your user's manual to see how. If you don't plan on using the Xbox Wireless Adapter for your Xbox, you may skip this step.
  3. Step 3 Run a network cable (Ethernet) from your router or directly from the modem to the Xbox 360. Once you have this cable plugged in you will have to access the "My Xbox" tab on your dashboard. Go to the "System Settings" portion of the tab, usually the last portion on the right, and access network settings. For wired setups, go to the "Configure Network" option and make sure both the "IP Settings" and "DNS Settings" are set to automatic.
    For wireless setups, you will need to have the Xbox Wireless Adapter plugged into the Xbox. Under the Network Settings, enter the security key that you obtained earlier to allow access to the Internet and Xbox Live.
  4. Step 4 Create an account on Xbox Live. You will need to either have a credit card or an Xbox Live subscription card. You can purchase Xbox Live cards at your local game retailer. You will be asked to enter information and create a user name called a "Gamer Tag." This is the name that you will be known as in the x-box community hope this help you out
Jun 08, 2010 | Computers & Internet
How to use bellsouth router on windstream internet
yes you have to configure it with the dsl modem plug your modem ether net cable into routers ethernet,open your modem configuration page by typing 192.168.1.1 login by using by default the router login are "admin"and pass word is also" admin" note down dns setting and other setting which yopu may need tosupply the router now open router login page and supply required connection setting change set router default address 192.168.1.2 soit should not conflict whith each other supply dns setting, enable wireless ,set wireless secuirty ,try now sitehr@gmail.com
Aug 16, 2009 | Westell Wirespeed VersaLink...
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
Placing Sppedstream Modem 4200 in bridge mode
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
Jun 14, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
TP-LINK Tenda W311R WirelessN Router AP 4port Switch 150Mbps Logo
749 people viewed this question
Top TP-LINK Computers & Internet Experts
 Mike M
Mike M
alex metro
alex metro
Pamela Bates
Pamela Bates
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
