I followed the instructions on LG's official webpage, downloaded the correct firmware file for this model, copied it to a USB drive on a LG_DTV folder. Although my TV sees the file and attempts to update the firmware, I get an error a few seconds later saying the file is corrupted. I tried redownloading the file again and using a different USB stick ... same result.
Just save your data and then reform the hard drive. Home Mail Help
SOURCE: I have a lg Model 50PC1DRA-UA Plasma TV-DVR
I would suggest reform the hard drive. That means you will lose all your data... should be an option in the menu..
SOURCE: usb problem lg pq2000
pq2000 does not have a movies option for USA, the pq3000 does. I also have the 2000..
SOURCE: My new LG LCD TV
Tries it with other USB memory sticks?See,if it could be that memory stick have problems.Tries it with other HDMI hub?
SOURCE: LG 32LH40 Firmware Update. Has anybody found one?
At the following website there are lg tv firmware updates but the 32lh40 is not listed. Likely you will need to contact lg support. I was looking for one just for general maintenance on the same model.
http://us.lgservice.com/vchip_html/V-chip_upgrade_for_your_set.html
