You can obtain the manual for this phone at the link below, which may help you reset the password.
http://phone.manualsonline.com/manuals/mfg/nortel_networks/nortel_business_series_terminal_t7208_nt8b26aabn.html
Cisco 48V Telephone Power Supply
SOURCE: nortel t7208
it seems like your system does not have disconnect supervision. set it to yes under trunk line data. that way the system knows when a call is released.
sean malone
SOURCE: how can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
SOURCE: I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
SOURCE: Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
SOURCE: checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
