Press the menu button and go into the setup menu. Find the time and date setting and set it. You might also have to reset the time and date stamp, if you want it to show on your pictures.
Every time I'd try to turn my camera on, it would give three beeps and then go off.
I decided to search your Fixya tips, and I found it. All I needed to do was press and Hold the OK/Menu button while I turned on my Samsung S630 camera and it worked!!!!!!
Thanks for the tip, and I hope Someone else will get the same benefit
Elizabeth Flood
The view screan on my Samsung S630 camera is all white looking and blurry! The photos that I take look the same.
Any tips will be most appreciated.
Elizabeth Flood
You may view the user guide here and the extended user guide here. See this page for loading the battery.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Try pressing your Display Button Twice. Once you should be able to see through your view Finder. Twice your be able to view your Subjects through your Display Monitor.
