Washing Machines Logo
Posted on Jan 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just moved from Detroit to LA and hooked up my washer, proceeded to run a load and the tub doesnt spin and the aggitator does not work and the water just keeps pouring! it is holding water and it is draining. I got it to aggitate for a short time with no clothes in it,(at the final spin). It is a Whirlpool ulitmate care II.
Anonymous
Level 2:
  • Expert 113 Answers
  • Posted on Jan 08, 2009
Anonymous
Expert
Level 2:
Answers
113
Questions
Helped
47507
Points
219
Sounds like you have your drain hose pushed in too far, causing it to syphon the water out. www.washermd.com
My top loading frigidaire washing machine barrel spins during wash cycle and the aggitator is going as well how do i fix it
Hello fire_rod - From what you have described it sounds like either the transmission is failing or the trunnion, which secures the tub to the transmission shaft has broken. Contact a professional to move forward accurately.
8helpful
3answers
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
The washing machine doesnt aggitate
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Top load washer not spinning
transmission may be going bad or you may have a sock or something stuck between the inner and outer tub
1helpful
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
1helpful
My washer will not stop running water at any load level run over
Washer has a pressure switch and hose that runs from control panel to side of tub. check to see if this hose is loose at control panel.
1helpful
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
1helpful
Washer won't aggitate or spin.
your water pressure tube is clogged at the tub. Take the back of the control panel off and blow or a small balst of compressed air down this tube and try the washer again. Powder detergent clogs this tube at the bottom of the tub and does not tell your pressure switch to shut the water off at the proper level thus overflowing your tub.
Aggitator or tub not spinning after move from detroit to LA
IT SOUNDS LIKE YOUR DRAIN HOSE IS LOWER THAN YOUR TUB WATER LEVEL BE SURE THAT YOUR DRAIN HOSE IS ABOVE THE TUB LEVEL.GLAD TO BE OF SERVICE
Top Washing Machines Experts
john h
