Problem Event Name: APPCRASH Application Name: QuickUp.exe Application Version: 6.0.0.1 Application Timestamp: 4e3ad274 Fault Module Name: opswatai.dll Fault Module Version: 6.0.0.1 Fault Module Timestamp: 4e2ab696 Exception Code: c0000005 Exception Offset: 00018b29 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
SOURCE: Problem Event Name: APPCRASH
hi,
well this error leads to application crash that means either you did not install app correctly or something went wrong in PC try this
Start - Run - net localgroup administrators NetworkService /ADD
Hope this works for you
SOURCE: problem with iexplore.exe
Can be so many things but first thing is first... Go to the control panel, go to internet options, click on the advanced tab and click the reset option. This will clear all add ons, internet temp files, custom installed stuff etc... If this doesn't work you might have spyware, corrupt IE, antivirus related trouble and the list goes on...
SOURCE: APPCRASH
nfs.exe "need for speed app." are you playing a ea game?update your graphics ,audio and keyboard drivers.rt, click on it go to properties check the compatibility mode. shutdown any unnecessary process in taskmanager,lots of people having problems.ea is working on a patch if you cracked the game yourself,it might be a bad crack..overwighting nfs.exe with original nfs,exe also helped a couple guys,good luck let me know if you discover any other fixes
SOURCE: Problem signature: Problem Event
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner it will solve ur problem
