I have read in another post that the DM part # 934C116002 is bad and needs replaced I have tried to locate this part on the web with out any luck. Can someone tell me were I can get this part for my WD-52725 TV.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
Can you send instructions with pictures on which 4 capacitors to replace?
My email is [email protected]
Thanks,
Ryan
Please i would love picture instructions to get to and remove the dm module from my Mitsubishi WD-52725, it has the blinking green light of death. Email is [email protected]
Techman, could you please send me the DM Board fix. I have Mitsubishi WD- 52725 T.V. with a DM Board issue.
Thank you very much,
[email protected]
care to share the instructions? [email protected]
Thank you!
Can you please e-mail me how to get the DM board out as well as locate it? Thanks. My e-mail address is [email protected]
Can you please also e-mail me a link as to where i can find the capacitors, thanks. [email protected]
My email is [email protected] and I have mits wd-52525. I would appreiciate the pics and directions for the capacitors on the dm. Thank you.
YES MY E-MAIL ADRESS [email protected]
I would like the instructions on how to find the DM module on a WD-62525 - [email protected]
Could you send me the pictures and directions to locate the DM board, the DM Board Fix, and the a link for the capacitors. My e-mail address is: [email protected]
Replaced lamp and now having blinking green LED. Can anyone provide the pics on how to locate and remove dm board for WD-52725 DLP?
The pics are no longer at the url given. can you advise where to get them?
Same prob's, would love some pics and directions
[email protected]
Thanks!
my email address is [email protected]. i have a wd- 52725. can you send me the pictures on removing the dm board and capacitors? thank you very much
same problem Mits WD52527. need repair instructions
