To stop beeping sounds
Good day Gloria,
Here is a parts list,
http://support.radioshack.com/support_electronics/doc68/68646.htm
refrence part number 12392288 COVER ASSY BATTERY, you can go to your local Radioshack and they can order this. Tell them that it is an RSU order, ask for a manager if they don't know what your talking about. That is a special wharehoues that they have for parts. Newly hired associated usually don't have a clue that it exists. Or call 1800-843-7422(1-800-the-shac) to order, they may redirect your call to a local store.
Follow this link for the manual,
http://support.radioshack.com/manuals/ome20-525.pdf
After skimming the manual my self I couldn't find much on the beep issue. It is possible that that beep is coming from the transmission you are recieving, does it that on all frequency's, or just certain ones? Keep in mind that that could also be a weatherband alert tone. I'm not sure, well I hope this helps in someways, If all else fails read pg 83 of the manual to reset the unit.
Good Luck
reword the question maybe ? trying to understand , all i can think of is you may be describing packets or birdies , not a clue .
how to program scanner
