Question about Motorola Mobility V3x Razr GSM World Cell Phone (Unlocked) Headset
Internal speaker failure asus f3jc
I was using my headphones, plugged into the headphone jack. Last night,
I noticed a red beam of light coming from inside my headphone jack that was never there before,
I thought "wow that's cool, this thing shows me something new and cool everyday"...wrong.
also got a joltfrom laptop
    Master:
  • 665 Answers
If the rest of the laptop works and you can still hear audio through the headphones. Buy and replace the speaker:
https://en.accessoires-asus.com/?gclid=EAIaIQobChMI27rs6-ba2AIVDrvtCh0y-wwhEAAYASAAEgLRbvD_BwE
If not it might be the power supply and that would explain the jolt and the red beam.
Posted on Jan 15, 2018
3 Suggested Answers
SOURCE:
SOURCE: Pairing HT820 with Blackberry Pearl
trying to connect to blackberry pearl 8100 to motorola HT810
Posted on Sep 24, 2008
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: I can only answer my mobile via speaker or headphones. Want is wrong?
    Rosemary
    Sorry it isn't working. Sounds like the earpiece is broken. Please contact us. CONTACT US to locate a service center.
    Mark
    Motorola Support
    Posted on Jan 08, 2015
    Macbook pro headphone audio
    Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
    Mar 21, 2013 | Apple Computers & Internet
    I have an asus g71gx running a realtek audio driver. I've reinstalled the driver, reinstalled a new OS, and I'm still not getting any sound out of the internal speakers, but when I plug in a...
    Did the internal speakers worked before? Do you use the right drivers here is the ASUS download link http://usa.asus.com/Notebooks/Gaming_Powerhouse/G71Gx/#download Maybe there is a "switch off" in the BIOS?
    The last option is that it is a HW failure - if the laptop is still under warranty I would use and not try to fix it by myself
    Good Luck,
    May 11, 2011 | Computers & Internet
    Can the audio be heard normally from the TV while these headphones are also being used? One person in the family is deaf and will use the headphones while the rest of the family will watch also with the...
    Randy - I don't know what TV you have but in general media devices turn the internal speakers off when you plug anything into the headphone jacks. If your TV does you can probably do the following for probably around $20 (USD)
    If you have a relatively new TV you could get a pair of inexpensive self powered computer speakers and a simple 3.5 mm to RCA stereo adapter. Then plug a standard red-white RCA stereo cable into the red-white stereo output jacks on the TV and the other end into the 3.5mm adapter and a 3.5" stereo cable from the adapter into the computer speakers.
    Or, if the TV headphone jack is 3.5" instead of the larger 1/4" headphone type you could simply get a 3.5" stereo Y adapter and then plug the headphones into one end of the Y and the computer speakers into the other.
    Either way sound for everyone.
    Thanks for using Fix Ya
    Mikeywaf .
    Mar 17, 2011 | Audio Players & Recorders
    Using headphones
    You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
    Jun 19, 2010 | E-Machines eMachines Desktop PC
    My sony 771 won t play any sound -- not the speakers because doesn't come through headphones either. Just cleaned the lens for CDs last night, then this problem developed. Can see the amp bars moving, so...
    The lit indication ("amp bars") proves that the aduio signal is getting through the unit's circuitry @ least to that point; lack of sound @ the spkr & headphones indicates the amplifier portion of the circuitry is either inoperative or disconnected from the load (i.e., either the speakers, or the headphones). A common cause of this type of problem cropping up unexpectedly is the headphone jack itself; in most products of this type, the audio path from the amplifier output to the speaker connection runs through the headphone jack, so the the speakers may be "turned off" when the headphones' plug is inserted into the jack. If the unit's owner uses headphones regularly, the most common problem to be found with the jack is loose solder connections to the printed circuit board's traces from the jacks' lead(s); in units with this problem whose owner's irregularly use the headphones, it's more common to find oxidization of the electrical contacts within the jack itself.
    Dec 10, 2009 | Sony Audio Players & Recorders
    My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
    Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
    Dan
    May 12, 2009 | Yamaha HTR-5730 Receiver
    Sound is working but internal speaker is not working
    Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
    If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
    Mar 01, 2009 | Dell Latitude D410 Notebook
    Headphone jack broken speakers wont work
    Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
    You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
    You can either try removing the blocked part using a Tweaser or get it repaired.
    Jul 31, 2008 | HP Pavilion dv9000z Notebook
    Built-in speakers problem!
    I dont think its a hardware problem, go to this site and go down to the XP drivers and download audio drivers and re install http://support.asus.com/download/download.aspx?SLanguage=en-us
    Apr 06, 2007 | ASUS m6n Notebook
    Motorola Mobility V3x Razr GSM World Cell Phone (Unlocked) Headset Logo
    160 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis Webber
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
