Labtec LCS 150 Computer Speakers Logo
A
Anonymous Posted on Nov 12, 2012
NEED TO REPLACE POWER SUPPLY
WHAT IS THE POWER REQIUREMENT FOR LABTEC LCS 150
Lonnie Arks
Level 2:
Scholar:
  • Expert 58 Answers
  • Posted on Nov 22, 2015
Lonnie Arks
Expert
Level 2:
Scholar:
Answers
58
Questions
Helped
60320
Points
144
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
5 Related Answers
A
Anonymous
  • Posted on Mar 29, 2008
SOURCE: Labtec LCS 1024
Do you have any schematic of Labtec 1025 with wiring conection? Thank you for your response it does help me alot
Anonymous
  • 4 Answers
  • Posted on Feb 08, 2009
SOURCE: labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Anonymous
  • Posted on Aug 23, 2009
SOURCE: no wires for labtec lcs-3210
1500mA @ 15VDC. I've got a set of these speakers and I just looked at the adapter.
Anonymous
  • 1514 Answers
  • Posted on Jul 21, 2010
SOURCE: I can't find a driver to install my labtec LCS 2424 speakers
You plug it into the headphone socket on the laptop
puertobori
  • 7733 Answers
  • Posted on Nov 09, 2010
SOURCE: need a driver for Labtec
Go to Labtec.com > Support > Downloads.
Opening Labtec speakers type LCS-1030
To open these you need to pull the front grille off. There are four screws, one in each corner. You'll need to do a bit of prying to get it open as the case is sealed around the edges, but it isn't too terribly difficult. Just take your time.
Labtec lcs 150 disassemble
Three screws (each speaker). One visible in the rear at the top, two more hiding in the battery compartment. Good luck. Broken wires can be re-soldered. Speakers may be replaceable (though in this disposable age your sources are drying quickly). Otherwise, off to Amazon for new speakers.
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
I don't know where to plug the speakers in to the computer (labtec LCS-150) I just moved from Vancouver, B C.
hello vivian10
your speakers should have a headphone jack, and your computer should have a speaker-in jack and a mic-in jack. plug your speaker jack into the jack on pc
2answers
Most speakers do not need any sort of software. All you have to do is to plug it in
I need a new power supply for Labtec LCS 1030 speakers and trying to obtain specs and power plug information. Anybody have the information available?
I know this is a little late, but the power supply that these speakers use appears to be 5mm across. The output specifications are 15V DC, 1000mAh (1A), with the center pin being negative.
1helpful
2answers
No wires for labtec lcs-3210
Top Labtec Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
