Windows xp hardware drivers for dell inspron 620 desktop computer
All drivers for the dell inspiron 620 series desktop computers can be found in the support section of their website. i have provided a link for you! http://www.dell.com/support/home/uk/en/ukdhs1/product-support/product/inspiron-620/drivers
SOURCE: sound windows xp dimension 3000
Replaced hardrive in a Dimension 3000, installed Windows XP Professional and have no sound. I go to control panel and the Sounds and Audio devices are grayed out saying No audio device installed. I tried to install the driver from Dell and I receive a message during setup that the Audio driver does not suport your computer hardware. There is only one driver and it is the R94481.exe. I did a diagnostics and the sound passed the test for the 8 tones. Other than that, I have no sound.
SOURCE: DVD drive will not respond to any form of media
did you install the driver of your motherboard?if so,you need to download and install the dvd decoder for your media from the manufacturers site. if you cannot play even cd, the problem is in your dvd drive.if your dvd drive comes with a driver then you have to install it.actually there are more solutions to your problem try follow the solution I've mention first,and if its still not working post your reply and i will give you another solution.
SOURCE: No Ethernet After Reloading WIndows XP and Drivers
Sounds like you need a driver disk for your motherboard, this usually will load and install the devices you are referring to. This may not have been included with a pre-loaded computer. Search on the Dell website or get the make and model of your motherboard and search on a computer with internet access for the appropriate drivers. This may solve your problem but if it doesn't then we can go from there. Sometimes these come on a floppy but with newer systems they are on a disc.
SOURCE: Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
SOURCE: Dell Inspiron 530s/531s desktop, Win. Xp
try to boot in "Last good known configuration settings" by restarting your pc and then press F8 before windows appear and then select the boot option i mention above. if this not work since you said that it can't boot to safe mode, your other option is to repair the windows or else reformat it. when you repair the windows you must have windows xp home edition cd installer, you load it to your cd/dvd rom and then restart your pc and press F2 or DEL button before windows appear in order to go to setup bios settings. in bios settings, you choose boot order setup and setup first priority to cd/dvd and press F10 by saving the changes and then press any key when you see the prompt so that it can boot up to windows xp home cd installer and then follow screen instruction that you arrive to windows repair option.
