Apple MacBook PC Notebook Logo
Anonymous Posted on Nov 13, 2012
LAPTOP DONT POWER UP
Michael Lawing
Level 3:
Master:
  • Apple Master 545 Answers
  • Posted on Nov 13, 2012
Michael Lawing
Apple Master
Level 3:
Master:
Answers
545
Questions
0
Helped
71558
Points
1165
Make sure that the power cord is plugged into a working outlet, that the prong section is connected with a clean contact to the brick, that the magsafe connector and port are both clean. Remove the battery. Now power on the laptop with the power button.
If this does not work, attempt to reset the NVRAM (http://support.apple.com/kb/HT1379). If this is still not working, you can disassemble the machine and remove the upper part of the bottom case (lifting the keyboard section, and try to reseat the keyboard connection to the logic board. This cable is what allows the power button to turn on the machine. If this fails to fix it, then you have either a bad i/o board, or a bad system board, or a bad power cord.
How do i test or bypass my power button 6 pin
Does your laptop make any beeps? These would be error codes.
tip
Laptop preventive maintenance
After purchasing laptop when you are charging it first time take care that
power should not be absent meanwhile. If so happens after 80% charging then it always charge upto 80% offenly. Dont spill a water or tea on keyboard.Dont leave laptop in alone without lock dont put it in a conjusted place always keep open to free air dont expose it to sunlight, dont place laptop near loud speaker keep laptop away from magnet it destroys the laptop discharging of a battery is very essencial take the back up always
keep it always far from dust
on Feb 28, 2010 • Computers & Internet
Lenovo 4446 NOT POWER ON
keep your laptop on charging for one hour and dont on. after one hour your laptop will show led on
2answers
I dont have charger . is there a way i may charge my laptop using a desktop pc
Hi
No, that is not posible. you might want to get a universal charger for the laptop, they are fairly cheep. At the bottom of the laptop you can see how much power the laptop uses like:
19V (Volt) 1,2A (Amps)
Regards
2answers
Toshiba P105, backlight dont turn on in my lap
If the LCD, inverter etc works in anothe laptop but not in the original laptop then it looks like a motherboard problem, possibly the power supply to the inverter.
How clear power on password in laptop
You have 3 choice (i mean, thats all i know:) )
1: Get a new BIOS
2: Get the password from latest user (dont know if laptop yours or not)
3: Get the BIOS Flashed (Which is costly)
There is no way to unlock it without open it ,sorry.
Good luck....
1helpful
Dell inspiron b120 laptop won't power up
i dont know why dell did this but you have to have battery to run your laptop. the ac coard charges the battery which runs the computer. I really know why but i dont like the configuration. it is so the power is clean to your computer and so the can have less parts in the laptop you need to get a new battery
1helpful
Dv6120us power button dont work
None of the buttons will work untill the power is turned on and no sound will be heard.
You might want to try charging the battery by connecting the AC adapter to the laptop and plugging it into the wall outlet.
With the AC adapter connected, try powering up the laptop.
I hope this helps.
Good Luck.
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the wall.
have you tried before to reassemble your laptop? if not...dont do that...because it will damage your laptop..if YES....open the laptop...remove the motherboard and replaced the power jack of the motherbaord...be sure that you find same model of the jack....if you find desolder the old jack and solder the new jack and return to assmble you laptop and put the charger and power on...good luck am 100% it will work..because this is my job..if still not work..dont hesitate to contact me..
The laptop fell while the power lead was inserted it pushed the pin to the side an stopped charging it now wont turn on
Replace the power supply or the motherboard of your laptop, if your laptop still has its own warranty try to call the technical support of your laptop manufacturer and asked them to replace your power supply or motherboard. But if you dont have any warranty from your manufacturer, you must still call them to purchase a new power supply or motherboard.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
