100.9400690A
SOURCE: cuisinart grinder-brewer coffee maker
Use the bursh that came supplied with the coffeemaker to clean around the exterior of the motor area, underneath the grind basket. Make sure the chute is clean as well.
-Tha Mp3 doctor
SOURCE: Tim Horton's home brewer Bunn coffee maker
Before you plug in the brewer, pour water into the top of the brewer, put the pot back on the warmer, and close the lid. after the water finishes running down into the tank, repeat this step. after the second pot, water should start to come out of the sprayhead and into the pot. after water quits running, plug in the brewer. The brewer should heat up in about 15 minutes. Make sure that the switch on the side of the brewer is turned on. Once the brewer has finished heating, you are ready to make a pot of coffee. Put a filtewr in the basket - it pulls straight out the front of the brewer- put in your coffee, pour a pot of water in the top, put your pot back on the warmer, then close the lid. Within 3 minutes, you should have a hot pot of coffee. If you leave home for more than a day or two, you should turn off your brewer heater, so you don't lose water from condensation. this will cause damage to your brewer. Enjoy your new brewer!!
SOURCE: Bunn coffee brewer leaking
Is this a lot of water, or just a small amount.
As the unit sits over time and runs heating cycles, it may have some vapor come out of the vents. That will cool and collect around the unit.
try turning the unit off for the weekends. If you still have water around the unit, then it may have a leak in the tank.
SOURCE: i need a pot for a kenmore elite 14 cup coffee
eBay or www.searspartsdirect.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Need a Keuring Coffee Brewer
You can download and print the instruction manual in PDF format by clicking these links:
User Manual
Quick Start Guide
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manuals
Thanks for using FixYa.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
