I can readjust desk top by going to display but it never did tjhis before. I did something to reset the broderbund print shop but I cannot get it back to where i can make this readjustments. Readjustments to the font size . we have already lost many of the projects due to the site not saving the projects and it was when I was trying to retrive them and print them that this problem occured.
SOURCE: saving/printing different font size
Try to do again a complete reset, then set all settings again to big fonts and try saving.
Ensure also that you use Dymo original labels, they have a tag at the back, non original do not have it.
Sometimes with non Dymo rolls the machine lose settings.
SOURCE: the arrow on top of unit does not line up with the direction the
Sometimes when you disconect your battery for what ever reason and later hook the battery back up you will cross the wires and the motor will run backwards.
SOURCE: how do I increase font print size for a printing
you will need to increase the size from the program you are using generally if you go to edit font. the program should give you alternate sizes to change.
SOURCE: The font size is very small on the my printed doc. and I want to increase the font size
Fonts and font sizes are managed within the program you are using, the actual font files, and your operating system (typically Windows). This is especially true with some languages on the internet - you will need Language Packs from the program manufacturer to successfully display the characters of some languages.
If the printer works with other fonts and other programs just fine, but is having a problem with one specific font or program, then you will need to contact the manufacturer of the font (Or Microsoft, if it is a font that came with Windows), or the program manufacturer, for more assistance. The printer only prints what is sent to it, if other programs work fine, then the printer, its driver, and the related hardware are fine. Any printer does also not include fonts in the installation of the printer driver, so reinstalling the printer driver will not replace or solve font problems. If the printer is not working from multiple programs, let us know so we can troubleshoot this issue. Otherwise, you will need to contact your program manufacturer for information on how to manage fonts or the manufacturer of your specific font.
SOURCE: new cartridge fails to connect
It sounds like the print cartridge is bad. Pull it out and look at the electrical contacts. If there are scratches going from one across to the other or ink on the contacts, you could be shorting out the cartridge. Is this a refilled cartridge? If so, all bets are off. Throw it away and buy an HP original print cartridge. Also, look at the contact points inside the printer carriage where you install the print cartridge. If you see ink across the contacts, take a cotton swab with a very little bit of water (not dripping) and wipe the contacts. If you see the dimples collapsed, you have a problem. This is extremely rare however, but can happen if something is jammed into the carriage.
Put your old one back in and see if the printer responds. This is an easy check to see if it is the printer or the print cartridge.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
