Question about Frigidaire FEF352 Electric Kitchen Range
Self cleaning oven instructions
I would like instrucions for the self cleaning feature.
  • 12 more comments
  • Anonymous Nov 06, 2007
    I have a Frigidaire self cleaning oven.. smooth top with speed back.. I do not have the directions for the self cleaning part and would like to know how to do it..?
  • Anonymous Dec 03, 2007
    I hit clean, then timer and nothing happens and I can't find the manual
  • Cec66 Dec 20, 2007
    How do I do it?
  • Anonymous Feb 16, 2008
    Hello, did you ever figure out how to clean your Frigidaire self cleaning oven? I have the same problem; cannot find my instruction manual. The stove is about 8 years old, has a smooth black cooking surface. The only numbers I can find on it are inside the oven door, 316065306. That does not come up as a model number on the Frigidaire website. Can anyone out there help??
    Thanks,
  • jonell Mar 11, 2008
    I hit the control for the self cleaning oven button and it said it takes 3hours....not sure it should take that l long I only have a few spots on the bottom of the oven......also should I take the grills out or leave them in.....and then after the cleaning do I wipe out the oven to remove the spilled spots.....Yes you have guessed it I to also lost my manual
  • chunt Mar 29, 2008
    Have the same problem with my frigidaire oven. Now the lock light blinks and the door is not able to be shut to the oven. Grrrrrr . . . .
  • Anonymous Aug 02, 2008
    I lost my instructions for how to clean my self cleaning frigidaire oven. Model # FGFL67DB.
    Can you tell me how to clean it - what buttons to push?
    Thanks
  • bmcintosh Sep 01, 2008
    how do I run the cleaning cycle on my oven? The last time I did it, I had a problem getting it to unlock the door.
  • rlockler Oct 03, 2008
    how to use sels clean
  • grommy11 Oct 18, 2008
    my sister in law has a Frigidaire elec. clean oven from 1985 or 1986 but lost her cleanung instr. can u help?
  • TENNESSEN Nov 23, 2008
    MY SISTER HAS A FRIDGIDAIRE SELF CLEANING OVEN/STOVE IN HER APARTMENT BUT NO MASNUEL HOW DOES IT WORK?
  • Anonymous Dec 24, 2008
    i lost the manual to my self cleaning oven and i want to clean it.
  • Anonymous Jan 07, 2009
    you would think that all you have to do is press the "clean" button and your oven will self clean, but of course why on earth would they make anything so easy..... I lost the instruction manual and can't figure out how to get the darn thing to clean....help
  • flowers123 Jan 11, 2009
    need manual for frigidaire 352 please
I tried pressing clean then the up arrow. Nothing. THEN I HELD DOWN THE UP ARROW FOR A FEW SECONDS AND 3 HOURS CAME UP AND it worked and my oven is now cleaning itself. Remember...HOLD DOWN the up arrow for a few seconds and it will work
Posted on Jan 31, 2010
  • rosiereed May 17, 2011
    Thanks alot... I was alittle nervous, thought I would ruin something. With your instructions it worked well.. PRESSED CLEAN AND THEN PRESSED START BUTTON AND THEN THE CLEAN LIGHT SHOWED UP IN BRIGHT RED. Easy as 1 - 2 - 3. Thanks again.
    Signed: Rosie Reed in McAllen, Texas
    Sniper:
  • 112 Answers
Not sure which model you have...there are 2 that fall under the FEF352 line.
Here is a link to both sets of manuals
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF352&User=
Hope that helps
Posted on Jan 24, 2008
I pushed the clean button and then the up arrow and 3 came up (3 hours) It worked beautifully!
Posted on Dec 31, 2009
To find the model number look inside the lower drawer. It will be listed on the right hand side when you look in the drawer
Posted on Apr 30, 2008
Please send me instructions on cleaning my self cleaning oven
Posted on Nov 19, 2008
I can't believe that someone can post a need for a manuel on the internet but doesn't call the store or the manufacturer.....interesting and ridiculous.
Posted on Aug 29, 2009
  • Brujona123 Aug 24, 2010
    Why would I when this took 30 seconds to find what I needed!
  • LJ Oct 02, 2010
    EXACTLY! THIS is what the Net is good for, not "Twtting" on Twitter... why don't they just call that stupid ($@
    New Friend:
Frigidaire models
RE34BA REG36A REG36CA RSE37BA instructions for self cleaning oven. Taken from owners manual:
Setting the controls:
1. Close the oven door
2. Make sure the clock shows the correct time of day.
3. Be sure the Start Time knob is set for the same time as
the clock. If not, turn the knob to the
time on the cock. The knob will thin
poop out.
4. Set the Stop Time
for 2 to 3 hours past the Start Time.
EXAMPLE: If the Start Time and
Clock read 1:00, set the Stop Time for 3:00 or 4:00.
5. Set the
Temperature Control to CLEAN.
6. Set the Selector to CLEAN. The door will lock and the oven signal light
will come on. The oven signal light will
stay on until the oven reaches its cleaning temperature. The clean light will come on when the oven
temperature reaches approximately 550 degrees.
The oven signal light will then cycle on and off to show the temperature
is being maintained. It will then go off
at the end of the cycle indicating that the high temperature phase is
completed.. The oven must now COOL FOR ABOUT 1 HOUR or until the interior
temperature has dropped below 550 degrees.
Only then can the door be unlocked.
The clean light will remain on until the oven cools below 550 degrees.
Posted on May 01, 2013
  • Peter Fixya May 01, 2013
    Frigidaire models
    time on the clock. The knob will then pop
    out.
    5. Set the
SOURCE:
Instructions for operating the self cleaning electric oven of General Electric? ?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Feb 26, 2011 | GE Profile 30" Self-Cleaning Freestanding...
Need instructions on how to operate self cleaning feature.
heatman101
Dec 13, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
Frigidaire self cleaning oven instructions needed...
most instrucions can be downloaded from manufactures
Sep 14, 2009 | Electrolux Ovens
Self-Cleaning Whirlpool Oven
Hello, I am cleaning my oven today. I went to the whirlpool.com website and clicked on customer support and typed in my model number which is located on the front inside panel of my oven. They will provide you the manual with the self cleaning instructions. I hope this helps.
Jul 04, 2008 | Ovens
Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
May 04, 2008 | Kitchen Ranges
Frigidaire FEF352 Electric Kitchen Range Logo
16,458 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
