Funai TruTech DVDVCR Dual Recorder Logo
Posted on Jan 06, 2009
Need manual for Funai SV2000 Model#WV20V6
I bought a used Funai DVD/VCR recorder and it didn't come with an owner's manual. I have not been able to use it, is there a way to get a manual sent to me or at least basic operating instructions? I tried the web site, but could not find a manual. I have also tried calling the 800 number, but was on hold for more than 10 minutes. Can you please help me so that I can use this product? Thank you. Jill
  • 1 more comment
  • vardah4840 Mar 30, 2009
    cannot locate manual to set up or operate. is anything availavle on line?
  • drlnjo Apr 13, 2009
    Lost owner manual in move need to know how to record DVD's
  • Anonymous Apr 19, 2009
    I ALSO NEED THIS OPERATING MANUAL
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Mar 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
4001
Points
6
Visit www.funai-corp.com and under manual type your model to download pdf.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2183
Points
    Recording
  1. When you want to record using the SV2000, turn on the machine and open the disc tray with the "Open/Close" button. Insert a blank DVD and press the "Open/Close" button again. The recorder will check for information burned on the disc and, for some discs, format the disc for recording.
    Press the "REC MODE" button on the remote control to set the recording mode. There are 6 recording mode options on the SV2000, all of which offer a different recording time. Each recording mode will display on the screen when you press the "REC MODE" button, as well as the total recording time for that mode. Note that the longer the recording time, the lower the quality of the recording.
    Once the recording mode is set, change the DVD player to the channel you want to record by entering the number on the remote control. Press the "REC" button when ready to record. When finished, press the "Stop" button on the remote control. You will see "Writing to Disc" on the screen and a status bar. Do not turn off the SV2000 until all of the recording is written to the disc.
    There are several additional recording methods available on the SV2000, all of which are explained in the instruction manual. To use all of the features of the recorder, review the manual. A link to a PDF version of the manual is located in the Resources section.
  2. Playback
  3. To playback a recorded disc, place the disc in the tray as described above. A menu with all of the titles recorded on the disc will appear after the disc loads. Navigate through the list using the arrow buttons on the remote control and press the "Play" button to begin playback. To fast forward or rewind the video during playback, press the "FWD" or "REV" buttons. If the recorded disc has chapters, press the "NEXT" or "PREV" buttons to skip through chapters during playback. Press the "Stop" button at any time to end playback.
  • Anonymous Jul 15, 2010
    More to the article, could not post all, too much. Find out more at:http://www.ehow.com/way_5341050_funai-sv...
1 Related Answer
Anonymous
  • 416 Answers
  • Posted on Feb 09, 2009
SOURCE: I need a owners manual
Please go to this link
http://www.funai.us/funai/support/index.html
Follow to Owners Manual and type your model
This the link for PDF for model wv20v6
http://www.funai-corp.com/6pdf/om/WV20V6.pdf
I just check it works
Good Luck
2answers
Funai WV20V6
VCR section seems have error in mechanism like incomplete loading of cassette, no spin of video head motor, high spin of capstan motor etc. You can observe above symptoms and let me know for further help.
Help quetion
Which brand of DVD-R disc did you use? What error did you get? What is your video source? Most TVs don't give video output. The tuner on the WV20V6 is an NTSC (analog) tuner. Thus you need to use a set-top box (OTA digital-to-analog converter, cable or satellite box) with the recording "channel" set to video input 1 for most channels or analog cable input to the recorder.
Verbatim DVD-R 8x, Maxell DVD-R 8X/16X and JVC DVD-R 2X have been tested and proven to work by the manufacturer. A number of DVD+R and DVD+RW or DVD-RW have been tested as well.
I've found that you have to test each batch of DVDs. Different manufacturing plants can lead to bad discs from a previously good brand.
The manual for the WV20V6 is available from Funai Corp (who manufacture the recorder for SV2000). The direct link is http://www.funai-corp.com/support/om/WV20V6.pdf . See page 25 of the PDF for tested optical discs. No CD-Rs will work.
I hope this helps. Please add a comment with more information about your situation for additional support.
Have a Magnavox MWR20V6 - have a few things going on, one the power shutting off automatically when i put the vcr on timer and therefore does not record, and 2 vhs tapes that are almost new, gets stuck
Junk it. It's identical to Funai WV20V6. I can't remember exactly what is causing the shutdown. But, I do remember that it says it can't be fixed. Read other posts here at Fixya.
"Funai wv20v6 dvd/vcr player recorder"
2answers
I need a owners manual for model:wv10d6. There was no manual with the sv2000 dvd recorder. sv2000, model#wv20v6
I have the Basic instruction manual if anyone needs it, email me - for it Quick Guide WV20V6 I will try to get it out to you.
6helpful
3answers
Cosmicson. You can download it directly from the official Funai support website using the hotlink provided below.
SV2000 User Manual for model WV10V6 (PDF 9.19mb) <--- click to begin immediate download
SV2000 User Manual for model WV20V6 (PDF 9.64mb) <--- click to begin immediate download
SV2000 Service Manual for model WV205 (PDF 2.15mb)
please email me for this service manual. Be aware this older model is a DVD player only not a recorder or combo unit!
Was this information valuable to you? If so, please take a moment to let me know either thru email or by simply rating this solution.
So you're aware, only a vote of "Fixya" will bump a member's rating up one point. Contrary to what you'd expect anything less (such as a vote of "helpful") will actually pull it in the negative direction!
Acknowledgement of this solution's accuracy and value will directly give it the greatest possible visibility to help many others who are seeking this same information.
It'll further provide those of us who make these contributions with the necessary feedback to be confident the time and effort required making them is worthwhile rather than an utter waste of time. Thanks for your greatly appreciated time and consideration!
[email protected]
I AM TRYING TO OBTAIN A USERS MANUAL. I RECENTLY PURCHASED THE DVD RECORDERVCR COMBO. IT WAS SV2000 AND THR MODEL NUMBER IS WV20V6. I WAS INFORMED THAT I COULD GO ONLINE AND DOWNLOAD THE NECESSARY...
Not a problem:
http://tv.manualsonline.com/manuals/mfg/funai/wv20v6.html
You'll need to register but you only need to enter first name, email address and password. A fake email address will work fine if you're worried about spam.
Hope this helps,
erch.
7helpful
3answers
FUNAI WV20V6 VCR-DVD
Arakawastore. As usual you'll need to register a username and password to logon with if you want to actually download the service manual. But you can see everything you want to know about it by clicking on the hotlink below without having to register beforehand.
If you're hoping to find it online for free all you'll do is waste vast amounts of time. If I had it in my PDF service library I'd gladly have provided you with it, just as I've done on numerous occasions before here on Fixya.
Not once has a single Fixya member ever bothered to acknowledge my having done so as you can tell by my huge 3 point ranking. Perhaps this best accounts for why we all still have to pay for them.
Funai SV2000 WV20V6 Service Manual (PDF 6.20mb) <--- click here for full info
[email protected]
Top Funai Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
