My son has a 97 ford taurus. It has been very cold here and the car wouldn't start, even with all of the things we did to it (heating pad, battery charger, jump from my car, etc.). The car will turn over, but never get to the full starting stage. It has finally warmed up some, but the car still won't start. Any ideas?
test the battery when cold as it could have a problem only when very cold, what condition is the plugs in and the ignition system which can cause a problem.
Use a flat blade screwdriver if its got two jubilee clips make sure the car is cold!,,,,as you risk burning yourself also after you replace the hose put water in and put heater settings on hot start the car let it get to temperature halfway on temp guage switch car off and let cool down completly check water level and top up if neede
I had a similar problem. my 99 taurus wouldn't start after it was hot until engine cooled down enough. It turned out that it was the fuel pump. It provided enough pressure when the engine was cool but as it heated up, the pressure would decrease. Then the engine was not getting enough fuel to even start.
This sounds like you may have broken a transmission line or damaged the transmission pan. the oil has leaked out of transmission that is why it will not move,
Do not start car until you have repaired the leak, running the engine will damage the transmission due to low oil in it,
you will need to add 2qts of transmission fluid then jack up the front of the car and look for the leak, if you do not see it then have someone start the car and look, you will be able to see it leak out, i thing it will end up being the pan, good day.
how long has it been since a tuneup was done to the car.this maybe all that is needed.check the tps as these have a problem with hard start when cold at times.it pobably wouldn`t hurt to have the fuel pressure tested when cold.the map sensor can cause problems as well it this situation
It sounds like the same thing that happened to my sons car. He was driving home from school and it just died on him. It acted like it wanted to start but would not. He replaced the ignition module and now it starts. He was gotting power from the coil to the distributor, but not from the distributor. Good luck
