Microsoft Xbox 360 Console Logo
Posted on Jan 06, 2009
Xbox:360 Audio Problem
My xbox:360 has until this day not given me any problems.
when the new 'xbox experience' came out, my xbox would only play sound out of the left speaker, it is not a fault with my TV, i have checked that.
My friends girl has received the same problem with her xbox:360 when she updated to the new experiance too..
I have fiddled with the audio setting on my xbox, nothing seems to work.
I think this may be something i will have to wait for an update for.
But, do you guys have any ideas ?
please, if you do, post them >_<
  • Anonymous May 08, 2009
    this is my 4th sysstem and now its happening to me. i have a fairly new tv so what im doing is getting the madcatz component cables. i have the extended warranty with my 360 just got it. is this something that they would fix for free? or does the sound have to completely die for them to look at.. in other words is just cracking enough to have to send it in.. very annoying because ive messed with all the settings. i hope its not the tv and just the cables. ill find out tonite
Anonymous
Level 1:
Scholar:
  • Contributor 30 Answers
  • Posted on Mar 07, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
30
Questions
0
Helped
3490
Points
30
Red ring is not the only problem with Microsoft Xbox 360. This amazing device also has some more common problems like Audio Problem but no video problem, disc read error etc. Microsoft is providing extended warranty only for red ring problem. Means you will have to spend some money to get this problem repaired also if you plan to send your xbox to Microsoft, you will have to wait for 3-4 weeks to get back your favourite Xbox. There is one more option in the form of DIY guide, this guide explains solving No Video problem with step by step instruction, so any novice can fix this problem
2helpful
10answers
Xbox360 wont play origanal xbox games
Some XBox games have both a 360 and original XBox version, so you can't play them on the 360. Other games simply aren't compatible. Your game may fall into one of those two groups.
Xbox 360. Brand new. Played 2 times. during 1st play lost power 3xs. One time without surge protector. Playing splinter cell. Xbox freezing up. Has happened twice. Is this normal?
my friend too faced same kind of problem ............
his xbox 360 get stuck and never turns normal soon .....until its been restarted
if you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide.........
all the best..........
click here to download
10helpful
My Xbox 360 makes a loud humming noise while i play
The Xbox 360 does not like to be moved when playing a disk some of the mechanics may have misaligned or slightly out of sync this may be reason the DVD drive is making those sounds.
I strongly recommend you remove any visible dust from the 360 especially the sides and air vent holes using a vacuum cleaner. Once youve cleaned it place it horizontal (never on carpet) on a flat surface well ventilated away from other devices that generate a lot of heat.
As for the 'shredding sound', place in **** game into the 360 when it starts to make those sounds again gently tap the 360 on top (where the DVD drive is) until it stops making that sound. This doesnt always work but has for me and many others.
My experience tells me that dust can build up not only inside the 360 but also the drive itself which can lead disc read errors and the sounds and you mentioned.
Remember DUST and HEAT is the 360's biggest enemy and can cause RROD, 1 Red Light Problem, and disk errors.
Hope this helps..good luck!
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
1helpful
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
My xbox 360 just grinded my brand new Rockband 2 disc.
The Xbox 360 is known for this. I would contact Microsoft as soon as possible.
Assistance by phone seven days a week.
1-800-4MY-XBOX
International (direct dial to U.S.): 425-635-7180
Hearing Impaired (TDD device): 1-866-740-9269 or 425-635-7102 Hours of operation (every day):
9:00 A.M. to 1:00 A.M. Eastern Time
6:00 A.M. to 10:00 P.M. Pacific Time
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
2answers
My xbox 360 doesn't want to play any 360 games but it plays xbox games.
hi,
Take a look at this:
http://support.microsoft.com/kb/909819/en-us
Also call 1800-4my-xbox and talk with them, you may can get the xbox360 replaced for a new one.
Also check these recent problems on xbox.com:
http://www.xbox.com/en-US/support/?WT.svl=nav
Good luck,
Cam
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
