Keypad does not work properly
SOURCE: sony ericson c 905 faulty keypad ..... help please
cant solve it mine been back shop 4 times since i had it in the end i contacted sony and they supplied me with new phone and guess what its done the same sorry but ya stuck with it lou
SOURCE: Sony Ericson Xperia touch screen keeps freezing,
Had someone else with the same problem, it's similar to a PC locking up when it is performing too many operations at once and the processor gets tired of waiting for ram to provide info. He deleted alot of old applications, contacts, and anything that is old or not needed. Then he took out the battery and reinserted it and it works fine. Not sure if it will work for your Sony, but it's worth a try. If that doesn't work you may have to do a reset on the phone. Good luck!
SOURCE: how do i get photos off the sony ericson xperia
Rather smartly, Sony Ericsson's installed its PC Companion desktop software on the phone itself, so the first time you hook it up to your computer you'll be prompted to install the tools.
Once installed, you're able to then install yet more SE software, like its Media Go tool, a Support Zone helper and Sony Ericsson Sync - the company's own way of ensuring your phone numbers are all backed up in case you drop your phone down a drain while out on a drunken escapade. Or, in the case of the Sony Ericsson Xperia X10 Mini, swallow it. Media Go is refreshingly simple for a supplied app - it's little more than a fancy Windows Explorer screen, letting you select PC folders of your music and dump them onto phone, or organise your mobile playlists and subscribe to podcast feeds. Fortunately, you don't have to use it at all - the X10 Mini will pop up as an external drive when connected to a PC, for your easy dumping of media.
SOURCE: how to transfer contacts from
This can be done in a few ways: synchronizing with Outlook/Lotus Notes, via SIM card or sending the contacts manually as vCard files. I've recently bought a Sony Ericsson Elm and wanted to transfer contacts from my old Nokia 6233. Take a look at my solution here:
http://gsmdna.net/sony-ericsson/how-to-transfer-contacts-from-nokia-to-sony-ericsson/
Hope it will work for you too!
