SOURCE: 2001 pontiac sunfire wont start
I have had the exact same problem. There is an ignition lock that probably went off. There is a fuse box under the hood. The fuse that says ignition on it pull it out and put it back in. This should reset the ignition lock. Its a safety feature because the car thinks that someone was trying to tamper with it.
SOURCE: left key in ignition overnight, now car wont start
I have a 2005 honda odessey. I left the key in the ignition in the on position. The battery is dead. Do I have to recharge or will it recharge over night?
SOURCE: 1999 Chevy Silverado ext. cab 4x4 truck won't
That is right. Could be security system. If anything fails it won't allow the vehicle to start.
SOURCE: 1994 olds 88 doesn't start. Lights work, bells
make sure that your battery is fully charge if it is. you have a starter problem and that should take care of you problem. let me know if i helped you. thank you.
SOURCE: 2007 chevy cobalt ls won't
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
