Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
Posted on Jan 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Date to appear on photo
I want the date to appear on my photos - don't know how to set it up on my camera
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Jan 06, 2009
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
951588
Points
10742
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Cannot get date to print on .jpeg images when downloaded
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want the date printed on your photos then please refer to the documentation for whatever program you're using to print. Depending on the program and printer you may have the option of printing the date on the image, in the margins, or on the back.
2answers
Would like to know how to insert the time and date stamp onto the Canon A710IS please. Thank you
Download any manual about this product by visiting the link bellow. hope it what you looking for.
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a710_is#BrochuresAndManuals
Thanks for using fixya,
May 16, 2011 • Cameras
2helpful
Trying to set date/time for the first [ what is the wrench button?]
The "wrench" is NOT a button, it is an icon in the menu.
Press the MENU button. Press the Right/Left button to select the "WRENCH" icon The Setup menu appears in the center of the LCD. 3. Press the Up/Down buttons to select the Date option in the Setup menu. Press the MENU button. Press the Up/Down buttons to select a Date option from the Menu that appears: On selecting "On" the date will appear on the photo once it is taken. • On selecting "Off" no date will appear on the photo. • On selecting "Set Date" the Set Date settings screen will appear. You will be able to • change the date settings that will appear on the photo once it is taken. To Set the date: Press the Up/Down button to enter Set date option. 1. Press the MENU button. 2. Press the Right/Left button to select and highlight the Year, Month, Day, Hour, Minute, 3. Second and Date Format type. Press the Up/Down button to set the Date, time and format
Please...which is the wrench button? vivitar x327 trying to set up date/time. for the 1st time
1helpful
I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS ON MY CANON REBEL T2I
theres no date a time stamp on the photo itself with DSLRs but the meta data is kept on file in the photo so it has recorderd the time and date. depending on what photo printing software your using you can bring up the time and date back on the photo. I have canon photo printer and using the bundled software easy photo print, it allows me to print time and date of the photo. or if you use adobe lightroom you can get the time and date back on the photo. the time and date stamp is more of a compact camera rather than DSLR.
How to make date etc appear on back of photos
The date usually only appears on the front. However, most retail photo labs (i.e. walmart) can add custom backprinting to your photos. You can usually only add one line of text for entire order and custom pricing would probably make this a little bit expensive. On that note, the date you have your film developed/printed is usually printed on the back of each print for free, as this is default setting for the lab's printer.
2answers
Date stamp on photo
Check the options carefully, and read the manual.If you don't have a manual, they are free for the download at Sony. Look for you camera under support/downloads.
Some cameras only allow date and time stamp to be in certain resolution settings. It will not show up in other photo size settings.
Embedded date on photos
this camera has an internal clock battery, which must keep the date or any other related information while you changing the batteries, the problem is, since you camera is pretty old, the clock battery is probably long dead, it can be changed, but it will require disassembling and resoldering
Date still doesn`t appear on the photo in my computer
You need to take the photos with the date option on, and it becomes a permanent part of the photo. You cant turn the option on and off dynamically. Use the cameras menu to turn the date on and you should be OK from here on in! Thanks!!!
1helpful
Date doesn`t appear on the photo in computer
Download the userguide from the following link and please refer page 74 & 75 http://esupport.sony.com/perl/model-documents.pl?mdl=DSCW50 Good Luck
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
