Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
HOW DO I TAKE BOOTOM BURNER OUT FRIDIDAIRE GALLERY CFES 388REB1
THE BOTTOM ELEMENT IS BURNT OUT HOW DOES COME OUT
  • Official Brand Answer
  • 4,342 Answers
Hello rdbal - Most bake and broiler elements are typically held into place with 4-6 screws or fit(s) in a bracket like connection and then needs to be screwed down. However every unit is different so please contact a professional to move accurately for more information due to safety and liability reasons.
Posted on Nov 15, 2012
SOURCE:
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
Need to take bootom burner out of stove
Make sure you unplug the range.
There should be 2 screws on each side of the heating element, usually these are hex heads.
Remove the screws and gently side the heating element out a few inches.
You should then be able to unplug the wires to the element.
Hope this helps you
Jan 02, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My large dual burner does not heat up completely. Only the center burner works
The only way to find out the problem and repair it is to disassemble it..
Most have to be disassembled from the bottom, with the unit pulled and laying on a blanket to protect the top.)
Could be a bad switch, a bad element, or a wire is burnt off.
Good luck....
Apr 08, 2010 | GE Cooktops
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Element burnt out
replace the swich for that burner.thats the one behind the knob.
Dec 02, 2008 | Hotpoint RB787 Electric Kitchen Range
Bottom burner in oven dose not work but top burner work why
possible hat the bottom elemnt has burnt out/broken/shorted. you would need to check the element for continuity witha power meter ifits not an obvius break.. BEWARE ALWAYS LIVE WIRELEADING TO THE BAKE ELEMNT TURN OFF POWER FIRST!!!!!!!
Dec 02, 2008 | Crosley CE35100AA Electric Kitchen Range
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
66 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
