Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
Posted on Nov 11, 2012
I have 2009 52" Sony Bravia XBR. Trouble started with couple vertical lines - went away in short time. New problems started with top 25% of screen becoming "shaded," not pixelated. Then went to hal
Screen returns to normal 45 minutes later. Need help! thanks.
5 Related Answers
Anonymous
  • Posted on Oct 08, 2008
SOURCE: Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
roety
Eric Rotmil
  • 587 Answers
  • Posted on Oct 24, 2009
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Anonymous
  • 68 Answers
  • Posted on Nov 28, 2009
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Anonymous
  • 10594 Answers
  • Posted on Dec 13, 2009
SOURCE: Vertical Lines on Sony Bravia TV.
I'm afraid, its problem of LCD Panel (screen).
LCD Panel replacement is only solution for this problem and will cost you 70% of TV price, please contact nearest Sony service center for LCD Panel replacement.
Anonymous
  • 1099 Answers
  • Posted on Aug 11, 2010
SOURCE: l have a sony 46" Bravia XBR TV it is also almost
All Flat TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
1helpful
I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
13helpful
3answers
1helpful
2answers
Sony Bravia KDL-52WL140. We went to bed with working TV and woke up to vertical lines on entire screen with every input. My husband has disconnected all inputs and cables to check for any noise or...
it is fixable, but it depands on the cost, compared to buying a new 1..the problem is with the vertical deflection board....if can get it hope it will work..other options are, reservice the whole unit ..
9helpful
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
2helpful
2answers
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
