Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull
If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra)
If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
