Volvo S80 05 2005 Logo
Posted on Nov 11, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hard to select reverse - Volvo S80 05 2005
Anonymous
Level 3:
Master:
  • Master 689 Answers
  • Posted on Nov 11, 2012
Anonymous
Master
Level 3:
Master:
Answers
689
Questions
0
Helped
100840
Points
1974
Will have to be taken to a transmission shop to be diagnose,
After repairing transmission in Chevy S19 truck gears are hard to get why?
comment on your statement of "hard to get" gears
do you mean that selection is hard
the selector lever is hard to move
gears have no synchro action when changing gears
hard to get into first and reverse
The car has an automatic transmission and all of a sudden i had no reverse had no slipping or nothing the drive gears work fine no slipping grinding nothing shifts through all gears just fine
It may just need servicing/adjusting.
Your reverse gear is actually first gear ... when you select reverse another 'cog' fits into the toothed wheels to change the direction of first gear ... to give you reverse...
It may be a sticky valve or just a bit of adjustment (workshop job..) that is required.
What you can try ..
Start the car ... move the lever through all the positions several times (foot on brake..). Keep your foot on the brake and then put it in reverse and rev the car. Hard!
Try doing it several times.
An auto transmission works on valves opening and closing. Reverse gear - in comparison with the forward gears - is seldom used. The reverse valve can 'stick'. Try forcing it to open ... frighten it ... but keep your foot on the brake...
2006 diesel trajet, manual gearbox, all gears fine except reverse, hard to select at times, any ideas, please ??
Reverse syncro is going bad. Have lube changed and add Lucas trans fix . Might get lucky
How do I fix it.do I have to lubricate somewhere?
The problem is that by driving in 4wd on hard surface you experience what is known as torque wind up in the transmission, transfer case and drive lines. This loads up the gears so an actuator cannot move a selection until the torque wind up is reduced (reverse or shunt back)
IT is not a problem if you are on slippery roads , gravel, grass or any surface where the tyres can slip and relieve the wind up
If you persist in the practice of driving in 4wd on hard surfaces then be prepared for transfer case , drive line problems well before expected wear time.
1helpful
Gear hard change
Sounds like your clutch may be going
Ford focus gear kinkage
Worn bushings, bent shift lever, Broken engine mount is a possibility
Reverse wire for a Hyundai Santa fe MY2010, fitting Radio/DVD/GPS/ Reverse camera unit and looking for where to connect the signal wire to turn on the indash screen for the camera input. It is the car...
Hi i just ran a wire from the rear of the tail light its not hard to do or you can run it from the transmission switch which is were your Tbar where you select your gears
2answers
Hard to get into reverse
try shifting in to first and then reverse. reverse might be worn out. you can have that gear replaced without replacing the whole transmission.
1helpful
Designer 1 reverse won't select, no light at all
The designer 1 has a weakness of the reverse pad (rubber button set) on left side of the machine wearing out and not working. You can try pushing from different angle, or pushing hard, but it most likely needs to be replaced. If you did buttonholes with the buttonhole sesor foot (foot with a wheel and a cord that plugs in), it would automatically size the buttonhole and you wouldn't need to reverse and you can use "FIX" to tie a knot instead of reverse
Top Volvo Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Volvo Car Audio and Video Expert? Answer questions, earn points and help others
