Question about Apple iPod nano
Ipod will not sync
I have an Ipod nano 1st gen. When i plug my ipod in it says do not disconnect for about 3 seconds then it goes to the main menu. My computer does not react in anyway indicating that my ipod is connected. It will continue to charge but will not sync. I have older music on my ipod from a past computer as well.
    Problem Solver:
  • 18 Answers
HI WE REPAIR ALL OUT OF WARRANTY PDAs,BLACKBERRY ,APPLE IPODS,IPHONES, AND APPLE LAPTOPS SERVING EAST DELHI,WEST DELHI,NORTH DELHI,SOUTH DELHI,NCR,FARIDABAD,GURGAON,NOIDA PLEASE CONTACT US AT JULIAN JOHN : Preet Vihar, Vivek Vihar, Shahdara, Mayur Vihar, Patparganj and Lakshmi Nagar. Pitampura - Rohini - Punjabi Bagh. - JanakPuri - Rajouri Garden - Patel Nagar
Posted on Jan 08, 2009
SOURCE:
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
My 3rd gen nano will not show up on itune but it shows on my computer
reset it then plug it in it usually work for me to reset there are 2 ways
1) toggle "hold" switch on off three times making sure hold switch is off the press n hold down menu and center button from 3 to 10 seconds or untill apple logo appears
2) same as above but without toggling hold switch
press and hold menu and center button till apple logo ppears then plug in cable to ipod and then in to ur computer
Apr 08, 2010 | Apple iPod nano
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Ipod woulnt connect to itunes
Reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Then connect it to your computer and see if it is recognized by iTunes.
If not, try other USB ports on your computer, especially any on the back panel.
Dec 29, 2009 | Apple iPod nano
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Ipod Nano gen 3. Won't work unless into charger or dock
Hi! Try uninstalling the itunes and reinstall it after restarting your PC. If it doesn't help then try to install a diffrent version of itunes.
Dec 26, 2008 | Apple iPod nano 3rd Generation
IPod nano
can u dl latest verison of i tunes 7.6 1st ok try that
Jan 26, 2008 | Apple Ipod Nano Second Gen. Green (4 GB)...
Ipod nano 1 gig 1st gen, screen on, then goes out repeatedly.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If you need more assistance let me know. Good luck.
Nov 03, 2007 | Apple iPod nano
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Aug 24, 2007 | Apple iPod nano
Apple iPod nano Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Will Mishler
Will Mishler
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
