I just got a M.Z. Berger AW206 366 so the setup should be identical.
The watch has four buttons total. I'll name then by their positions. Top Left (TL), Top Right (TR), Bottom Left (BL), and Bottom Right (BR).
(BL) is your mode switch. Press it once at a time to toggle between modes, (Time, Chronograph, and Alarm). From the Time mode press (BL) three times. This will put you back in time mode with the seconds flashing. Press (TR) to toggle seconds back to '00'. Press (BR) to toggle to the next setting point, and (TR) to advance it. Just keep pressing (BR) until all the settings points are the way you want them. Note: In time setting mode it only advances the setting forward when you press (TR). So when using it to change hours display for 12/24 hour display or daylight savings time you just have to keep advancing the hour until it shows up correct. There is no DST or 12/24 display toggle on this watch. You just have to change the hours display manually. To exit time setting just press (BL) once.
SOURCE: How do i set the time on a timex 1440 sports
Here you go old chap:
http://assets.timex.com/manuals/
Cheers.
Hi
This might help you having a manual.
There are two options to get a manual:
1. thru mail, you need to provide the style number found in the back or beneath the number 6 on the watch.
2,. Thru phone, you need to provide the style number then the warranty and instruction will be mailed to you. Also can give to you over the phone.
Customer care number: 718 472 7500
Customer care Fax Number: 718 472 7661
Address:
MZ Berger and Company
Attn: Service Department
29 - 76 Northern Boulevard
Long Island City, NY 11101-2214
Also for more information you can click this link.
I hope this will help you.
Thank you for choosing Fixya.
