Husqvrna hu775h wont start
Suggest start w/ the basics : Air, Fuel, & Spark. Internet search indicates that it's a Briggs & Stratton engine, which I just worked on yesterday (165 cc version). Easiest things first - ensure that there is FRESH fuel in the tank. If it's been sitting there all year, drain it out and refill with new fuel. (make sure you follow mfgr's recommended fuel type.) If you have a primer pump, make sure you can hear fuel flowing when you depress it (typically 3 - 6 pushes to prime the engine). If not, then youi may have a fuel line or fuel filter clogged. If you remove cowling/covering over top of engin, you can get access to the air cleaner. Remove the air cleaner/filter, and you can see into the carbuerator. This should make it easy to see if the primer pump is squirting fuel when depressed. While the air filter is out, make sure it is clean. If gunked up, I usually soak it and wring it out in fresh fuel, then let it air dry to clean it out (mine is made of foam). If it's a cartridge type air filter, blow it out w/ compressed air, or put a new one in if it's dirty. Lastly, if you have an assistant, you can check to see if you're getting a spark. Remove the spark plug, inspect if for correct gap and overall condition - remedy if you see something wrong. Then with it out, connect the spark plug cable (the high voltage line) to the top of the plug. Now, while touching the threaded part of the spark plug to a bare metal part of the engine case or lawnmower chassis, have your helper pull the starter cord and look at the plug's gap for a series of sparks.
If you don't see any sparks jumping the spark plug gap, you may have a bad plug, bad cable, too big a gap, or a bad magneto, or corroded connection to the top of the plug.
If you don't have fuel flow, you may have a clogged fuel line or fuel filter.
Air flow is pretty basic, so with the air cleaner removed, it should be pretty obvious if you have an airflow restriction. You can leave off the air cleaner/filter to troubleshoot the engine and to start it, just don't operate the mower without it, or you risk sucking in junk, rocks, you name it, into your engine.
THis may go without saying, but also inspect all linkages, springs, cables, etc. IF you see something loose or broken, check the owners manual or diagrams and remedy that. Also check out the Troubleshooting section in the owner's maual (available on-line at Husqvarna)
My problem yesterday was very simply BAD, OLD GAS. Briggs & Stratton make a pretty reliable, easy to start lawnmower engine. But even that's not enough if you're feeding it bad or contaminated gas.
