SOURCE: treadmill will not operate when plugged up.
check the outlet first by plunging in a light to make sure their is power and that the house breaker was not tripped. then plug in the power cord next locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset position. Then place safety key on console and the display should light up if not then you may have a lower board problem.
SOURCE: just bought from store press reset button it
Make sure the safety key is inserted this engages the power up sequence for the unit to start operating.
Also as a simple test try to get the unit into calibration mode by pressing the stop and speed up buttons at the same time while inserting the safety key
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
If either attempts fail then call the store where you purchased the treadmill, either have them send a service tech out or exchange theunit.
SOURCE: I was walking on a 200CS Weslo Cadence treadmill
LOOKING FOR THE USER MANUAL FOR THE Weslo CADENCE 200CS Treadmill
