? 2:09
https://www.youtube.com/watch?v=dXLzsEm1-0Y
Oct 20, 2010 - Uploaded by 1969Bossman429
We dropped our 2000 Cadillac DeVille DTS off at the local Cadillac ... He got into the vehicle, turned the key and the vehicle was still revving at full throttle. ... He raised the hood, reached in to the throttle body area and cycled ...Missing: 1994 ‎chatter ‎activated
Jan 17, 2005 - For my Review I will write about the 1994 Sedan Deville. ... A stifferbody this year made the Deville much quieter over the outgoing 1993 DeVille. ... First is a key when your looking at just about any Cadillac, push "off" and "warmer", this ...Have a helper hold the throttle plates wide open with the engine off.
CarGurusJan 21, 2014 - Cadillac Deville 2001 won't start, engine won't turn over - My cadillac won't start. When i turn the key the engine wont turn over and when i do turn the. ... bad replace was told alt was intermenting so that's wat caused issue now car .... intake plenum (the tube between the Mass Air Flow and the throttle body).Missing: 1994 ‎chatter ‎activated
Knock sensor is on the right (passenger) end of the engine, and will activate if at least one of the cylinders is misfiring. Your rough running engine can be caused by many many issues - I suggest you start with plugs and plug wires.
I have seen this problem before and the cause could be TCC Staying in Lock-up or an Electrical Issue within the Engine itself or a Fuel Delivery Issue.
If the Transmission TCC is the issue, try driving at slower speeds (below 30 and come to a stop, does it Shut off then? Increase Speed by 10 and try again. Does it react differently once you go above 42-45 MPH?
ok first, the fan it wont stop running cause is trying to cool the engine down, due to the leak, is it leaking from the warter pump? if the water pump is the problem you need a special tool to remove the water pump ant to put the new one in place, and that will fix your problem but first the leak, thats causing all the problem. Thanks
The "check engine" light will "light"
when there is a malfunction in the engine management
system. The fault code is then stored in the computer.
The computer must be scanned to retrieve these stored
faults to pinpoint the malfunctioning component.
We recommend buying your own scanner and doing it yourself. With a
pocket scanner
you can check for fault codes to find out why the light
came on in the first place. You can clear your cars
trouble
codes
after you replace the malfunctioning sensors.
