SOURCE: Cracked glass on front glass
if the tv turn on this will tell you that the plasma panel itself is ok. if it is ok then the fron glass is replacable. this is just a standard piece of glass so i really wouldnt spend tons of money hiring someone else to order one and install it.
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
SOURCE: 50 " Samsung Plasma TV
I have created a group so we can join and try to solve this issue, please register at [email protected] so we can get organized and get a lawyer, I have seen more than 30 people online... hopefully there are even more. Thanks! Suarez
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Follow up clarification: the crack is internal. The outer glass is completely smooth. I am not sure if the two year old cause the crack as no one witnessed it. It was just an assumption.
