It's 2 years old and used very little, heated first item fine put the next one in turned it on and the buzzing started very loud and has been the same ever since.... no metal was ever put in the unit...
Aug 12, 2011 - 10 posts - 2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
I have just replaced the magnatrton for a Kenmore microwave model # 665.606.5900 as before replacing the part there is still the buzzing sound and non-heating
I have a GE counter top microwave oven. When the oven starts cooking (the magnetron turns on) the oven makes a harsh buzzing noise. What is wrong and what should be done?
The noise is probably from the high-voltage transformer. When it
is overloaded, the excess magnetic field it produces vibrates its wire
coils. Odd that it only happens for a brief time. It is
either defective itself (in which case it may go a long time) or it is
getting overloaded by the magnatron/capacitor/diode on its output (in
which case it will get worse shortly)
Hope Ya Fix it
The most likely causes are a shorted high-voltage diode or a bad magnetron.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron.
Did it sound something like someone making a "gurgling" sound into a coffee cup?
I think this has a a one-year warranty, with n five-year warranty covering the magnetron.
You can find a local Amana-authorized servicer here:
http://amana.com/amana/jsp/portalhttp.do?cs=0&BV_UseBVCookie=Yes&NextPage=7
With the symptoms you
have, I would most strongly suspect a shorted high voltage rectifier
The magnetron would still be under warranty, but the labor would not be covered.
If you or someone you know would look at it, I could reply back with more detailed info.
Would that be the case, or would you rather call Sears for service?
