If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience. http://electro-medical.blogspot.com/
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER"
and "QUICK START" buttons in rapid succession. The "RESET" button can
also be used, in place of the "Stop" button.
Press the "ENTER" button three times to access the treadmill's error log.
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
To view the treadmill's odometer reading when a particular
error code was elicited, press "SELECT" while a particular error code is
displayed.
5
To clear the error log, press "QUICKSTART" for a minimum of
four seconds while viewing the list. Prompts will appear on the display
and let you know when the log has been deleted.
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL 2 If there is NO Fuse and you just bought it new Return it for an exchange. 3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
